1- The dreaded Sub-Tropical Jet Stream is still streaming from the SW with 80% and decreasing cloud coverage and scattered sprinkles.
2- These clouds will thin randomly, so Coastal Valley heating and thermal winds will not be reliable.
3- A huge North Pacific High lords over the Pacific, and it is pushing high-pressure toward the 4-Corners region, so spotty El Norte upper-teens to low 20’s winds are developing north of La Paz.
4 – Low-pressure south of Cabo will suck and accelerate those winds over our OUTER waters.
5- To get those winds to curve to our beaches reliably, we will need some fortuitous large holes in the clouds.
6- Even if you spend more time in bars than churches… a few prayers may be in order!
La Ventana: With lucky clearing UP AND DOWN upper-teens to 20 mostly outside.
El Sargento to Rasta: With lucky clearing UP AND DOWN upper-teens to 20 mostly outside.
Los Barriles: With lucky clearing UP AND DOWN upper-teens mostly outside.
