Actual wind velocity HUMAN forecast for Rasta Beach, La Ventana and Los Barriles is located on ikitesurf.com iwindsurf.com sailflow.com and fishweather.com
Today’s Wind Recipe:
1. To get the strong wind outside we need the heavy clouds to clear which is IFFY.
2. Strong NNW wind from the North Pacific High already streaming out by Isla Cerralvo. Rasta Beach is seeing a hint of this wind.
2. Weak, more favorable, NNE wind is headed our way from high-pressure near the 4-Corners.
3. Low-pressure south of Cabo is sucking that wind down the Sea of Cortez.
4. The cloud mass you see in the blog above has to clear to allow the Coastal Valleys to heat, making local low-pressure.
5. Strong NNW winds aloft add a major Gust/Lull factor.
