A Slack discussion: Learning to recognize a pattern for very up and down winds in the Columbia River Gorge
by Matt Sounders & Mike Godsey
look at all of those vertical strat-cus west of the Cascades
there must be a lot of mid-level cool air
indeed
they erode and are replaced by that garbage strat-cu
very clearly replacing the cool stable layer with a cool unstable mid-level layer
yeah…these rocking animations are highly useful
that could actually be pretty amusing
now you see the thin inversion…now you don’t!
alas, the models were way overestimating the thickness of the marine inversion on Monday/Tuesday for today so I expected today to be better for longer
very…very-weak top-of-boundary-layer inversion in the morning, then immediately wiped out by steep lapse rates in the midday period
it looks very muted even on that profiler chart
what about Portland?
or Astoria
so it would appear.
You can see it arriving at Astoria
no inversion at all
quite cold at the top of the boundary layer
modeling as of late Monday had a little bit of an upper ridge over the NW US…instead it’s a little bit of an upper-trough
that makes a large difference
yes
new messages
the users are getting a bit savvier and have higher expectations these days
